I plan to use 6 fans. 2 in the top, 2 in the front and 2 in the rear. Most likely 140mm's in the top and the other 4 will be 120mm's. I wanted to know in what direction should the air flow for the ideally lowest temperatures? I'm aware that hot air needs to flow out of the case while cool air flows in but what is the best way to go about that? Also, is there a better fan set up than the one I plan to use? I'm open to all suggestions. All of the fans are by Corsair and I did order a fan controller as well. Much appreciated - Alex
http://pcpartpicker.com/p/dNDC23
