Airis 1080 ti windforce power problem i think
Timpel
5
Hey
I Just buyt a aorus 1080 ti windforce.
But when i instal it in my computer its say connect tour power supply cables. But got it connectd
And got a 875 power supply a Dell h875ef-00
atleast i think it is, i look on internet for it.
When i start Up my pc and look at the power supply cables on the card only 1 led lights up and 2nd dont.
Can you guys help me out
Thanks you
Got a Alienware Aurora r4 pc
Sorry for nu bad english
Greetz Timpel
Am going to say that i do not trust the Dell h875ef-00 PSU I dont know what happening with your GPU but do think your PSU is low quality and abit risky because if this breaks one day it could take out your expensive graphic card and such!
https://imgur.com/a/k1TWNa0
Have you made sure that all these slots are full in red circle and not loose and made sure that gpu is in the pci slot and fitted correctly
Yes they fitted correctly. And the cables are not loose check it 5 Times
Ok i will buy a new PSU at Mediamarkt and will let you know if it workshop then
Thx for your help
Whats your system specs? If you have, let's say (besides cpu and gpu) only have 1ssd and 1hdd installed a 500W is enough. if you have many drives, many casefans i'd aim for 600W
EDIT: also because of you mentioning mediamarkt, I assume you live in either germany or austria, in which case i'd recommend getting the psu over amazon. deliverytimes are excellent with amazon prime (you can create free 30-day trial account) which will arrive the next day in most cases. also you have more to choose from as mediamarkt often hasn't that much in stock
With the 1080ti you need atleast 600W Or More!
no that's just not true. yes it's what manufacturers say but a system without much stuff in there besides cpu+gpu+ssd will never even come close to drawing 600W. a high quality (gold rated +) 500W is enough.
