[SOLVED] Airpods Pro not connecting
njitgrad
125
Just installed Windows 10 on an M.2 mounted on an Asus Prime Z590P.
Any reason why I can't see my Airpods Pro in BT setup? I see them on my phone and I see other devices in the house on the PC, just not the AirPods.
If you're having trouble getting your AirPods to connect, make sure your AirPods are charged, Bluetooth is turned on for the device you want to connect here, and reset the device before trying again. If none of those steps work, you should unpair your AirPods from your device, reset the AirPods, and try to reconnect them.
