Alienware Alpha ASM100-1580 won't turn on. Lights are yellow and solid. Blue light on power cord is on. Any ideas?
Kristy_8
Commendable
Dec 26, 2016
Alienware Alpha AMS100-1580 console won't turn on...lights stay solid yellow. Blue light on power cord is on and fans are on and running. Any ideas?
It sounds like your computer is on, just the display isn't...
Try turning it off, connect an external monitor, turn on the external monitor and then turn on the laptop.
If you can see on the external monitor, then the attached display or the ribbon cable that connects it are your most likely problem.
If you can't see on the external monitor either, but are certain there are sounds within the laptop, then your graphics card/GPU is the issue and will need replacing (and possibly the motherboard will need replacing).
