G
Guest
Guest
A friend of mine has an alienware Area 51 build made by dell. He dropped it off and asked me to look at it, he says he thinks lightning got to it. With the PSU plugged in The interior case lights, the MOBO lights are on and the Vents on top Move. But when you press the Power Button on the front Nothing happens. I Tested the PSU with a paperclip and it came on as well as everything else in the case, the Fans, and CD drive, My guess is that these came on because they are connected to the bottom command board and not the motherboard. My guess is that this may be a bad Motherboard but Im concerned about the other Small Control board at the Bottom. Does anyone know a way to test this small control board?
The control board is a MS 4195
The Motherboard is a MS 7543
