I'm getting an ANNOYING error for my alienware laptop boughbt in 2009. M15x. It keeps saying the error message below when i try to open alienware control center.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at AlienLabs.AlienFX.Controller.LightsZoneController.SupportChangeBrightness()
at AlienLabs.AlienFX.Controller.ControllerMainForm.configureTrayIconContextMenu()
at AlienLabs.AlienFX.Controller.ControllerMainForm.initializeTrayIcon()
at AlienLabs.AlienFX.Controller.ControllerMainForm.controllerMainFormLoad(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at AlienLabs.AlienFX.Controller.ControllerMainForm.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
AlienwareAlienFXController
Assembly Version: 1.0.92.0
Win32 Version: 1.0.92.0
CodeBase: file:///C:/Program%20Files/Alienware/Command%20Center/AlienwareAlienFXController.exe
AlienwareAlienFXTools
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienwareAlienFXTools/1.0.92.0__bebb3c8816410241/AlienwareAlienFXTools.dll
Alienlabs.CommandCenter.Tools
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Alienlabs.CommandCenter.Tools/1.0.92.0__bebb3c8816410241/Alienlabs.CommandCenter.Tools.dll
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
AlienLabsTools
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienLabsTools/1.0.92.0__bebb3c8816410241/AlienLabsTools.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
WindowsBase
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationFramework
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
AlienFX.DeviceDiscovery
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienFX.DeviceDiscovery/1.0.92.0__bebb3c8816410241/AlienFX.DeviceDiscovery.dll
AlienLabs.MasterIOBoard.Communication.Core
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienLabs.MasterIOBoard.Communication.Core/1.0.92.0__bebb3c8816410241/AlienLabs.MasterIOBoard.Communication.Core.dll
AlienFX.Communication
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienFX.Communication/1.0.92.0__bebb3c8816410241/AlienFX.Communication.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienLabs.MasterIOBoard.Communication/1.0.92.0__bebb3c8816410241/AlienLabs.MasterIOBoard.Communication.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.4926 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
LightFX
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/LightFX/1.0.92.0__bebb3c8816410241/LightFX.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
And i can't get the lights to turn on. I tried re installing windows 7, no luck.. tried correctly installing net framework 4 no luck, reinstalled the ACC, no luck again. Bleh. help please? thanks
mscorlib
System
System.Drawing
AlienLabsTools
System.Xml
WindowsBase
PresentationCore
System.Management
System.Core
LightFX
enabled.
For example:
<configuration>
</configuration>
