I recently bought a Alienware Aurora R7, which contains:
Intel(R) Core(TM) i5K-8600K (6-Core, 9MB Cache, Overclocked up to 4.4GHz across all cores)
Radeon 580 RX 8gb
1TB 7200 RPM SATA 6Gb/s
850W EPA Bronze PSU Liquid Cooled Chassis
16GB DDR4 at 2666MHz Dual Channel
I'm new to OC'ing, but I got the this K version so I can overclock my first CPU. However, I'm utterly confused.
Without ANY overclocking, CPU-Z and Task Manager is saying my core speed is at 4.8ghz, which is much greater than the stock 3.6. Why if I didn't do anything?
Also, when I go to the Alienware Control Center and turn OC Stage 1 (4.4ghz) or OC Stage 2 (4.6ghz) ON, my core speed goes down from 4.8 to whatever the speed of the OC Stage is set. Basically when I OC thru the Alienware software my speed goes down. If I select OC Stage 1 it goes down from 4.8 to 4.4ghz. What is happening?
So did my CPU already came overclocked @ 4.8 ? Are these two Alienware pre-set OC stages useless? By the way my temperatures are good, under 40c while idle and doesn't go over 70c while gaming.
Radeon 580 RX 8gb
