alienware replacement battery not charging
Defined tK
31
so my old battery (1 year old only) only charges to 20% so i bought a new one. When i put it in it says plugged in not charging. the battery is 0 days old so idk why its not working. It says 88% but when i remove the AC adapter it turns off.
*note* I MAY have damaged one of the pins (bent slightly then re straightened) but my old battery still works fine (other than the fact its got no juice left) and new battery doesnt charge
Is this normal for new batteries?
i bought it from dell so i hope its legit :/
i have the same problem too but ur alienware at least charges up to 80% but mine is right now at 0% but still charging which i hate i went to a local computer store and replaced the battery and it still does the same crap. i need solutions. thx
