Alienware x51 R2. Upgrade help concerning PSU and graphics card.
jjkennedy2176
Ok. So after looking to all the dark corners of the internet, I have come up with two main things
-In order to upgrade my graphics card from the GTX 645 it is currently, I need a larger PSU, preferably a 500w.
-Alienware does make a 330w, but not a 500w, thus leading me to believe I will need a new case if I want to upgrade my G-card.
I am asking the community if they can present me any other solutions I have not already thought of. Money is not an obstacle, however if your proposed plan's cost becomes to high, consider that I would probably just buy a new setup. I am trying to salvage my existing setup, before nuking it and starting over.
A easy solution would the GTX 750 Ti, this will give you much more performance while retaining your PSU.
I had fix an alienware for someone recently, had a blown PSU - coulnt get hold of a alienware replacement, and when using a normal 3rd party PSU I couldnt connect any of the weird case power parts (flaps and lights... yeah dont ask), also the alienware AIO liquid cooler had a proprietary connection. Real pain, in the end I removed it all from the shit alienware case and put it in a another standard case, replaced the PSU with a EVGA unit and the AIO with a corsair version.
Corsair CX 500W is only about $50. More than enough for your needs. But if you want headroom for future upgrade then look in to AX version of 700W or other brands. They tend to be around $130. As for which graphics lots of options.From R9 270 to GTX 980. Just matter how much you are willing to pay.
But since your computer is alienware which is a prebuilt computer. Better check if your bios isn't locked. Because pre-built manufacturers do sometimes lock out their bios meaning they won't let you upgrade your computer.
This is a lesson to you people that you shouldn't buy overpriced crap Alienware. Just build your own computer.
Which 750 TI though tried that and the power was @the inverse location of the stock gpu. Making it an impossible fit.
What do you mean? The 6 pin power connector wouldnt reach?
Easily solved with an extension cable
http://www.amazon.co.uk/Akasa-AK-CBPW07-40BK-Flexa-Express-Extension/dp/B004ZKXUD0/ref=pd_sim_computers_4?ie=UTF8&refRID=195VJNJDSHNJNCTH879F
Latest posts
