Hi, I am having a strange problem with my rig. For ages I have been running my E8500 @ 3.8GHz with no problems what so ever. Just the other day my system froze and when I went to reboot I would get POST but fail to load Vista 64. The only change I have made to my system is the addition of an Asus Xonar D2 sound card. I don't think that would be the cause, since it works just fine when I set my timings and volts back to stock (which is perfectly stable). Here are my specs: As I said CPU is C2D E8500 3.16GHZ stock, MoBo-Asus P5N-D, 2 GPU's Evga 9800GTX+ in SLI, 4G of Mushkin Enhanced ram @ 800MHz, PC&P Silencer 750watt power supply, Sound card-Asus Xonar D2. That said my OC settings were: CPU @ 3.8GHZ, Memory unlinked @800MHZ with a 1:1 ratio with FSB @1600MHz. CPU voltage- 1.325, Mem voltage- 1.91, NB&HT-1.44v, SB- 1.52v. Like I said I was stable for the past year, now I get random freezes at the speeds/voltages. Is it possible that with the addition of the sound card I have to up the NB voltage? Could my CPU be dying? MoBo on it's way out? PSU dying? Who knows! I have tried flashing my bios (same version 1101) incase of corruption, that didn't help. Any help would be appreciated. It is just really strange that suddenly OC'ing my rig causes freezes.
