All thinks work on starting my pc all fans work phase led all solid except 2nd led
All thinks work on starting my pc all fans work phase led all solid except 2nd led.....no boot no display only no signal message on monitor.....tried removin graphics card tried clr cmos tried removing cmos battery but didnt wor help plzz
Sys spec
Phenom ii 965
V8 cooler
Msi 785g-e53 mb
850w silent pro m
Cm 690ii advanced
Kingston 1333mhz value ram 2gbx2
Saphire hd 5830 1 gb
I was trying overclocking but seeing temp increase so put to default val but cpu vddc value did not come down from 1.432 it was red in amd overdrive
Help plzzz tried even resetting cpu n cooler checked all cables
Have you opened your case an reset the bios back to factory default settings.
Power off the system.
Open the side of the case and look inside.
Next to the coin cell battery there will be a set of three pins with a jumper bridging two of the pins. (Bios reset.)
Move the bridge one pin over for about ten seconds and place it back to the position it was in.
Power the system up.
If the system boots, you may have to go into the bios of the board to change some settings like the boot order of your HD and the type of interface mode Sata mode or AHCI.
Yes i did i hv a bttn instead f jumper i prssd it for 1 min but no results
May of over volted your CPU or damaged the board.
The only way your going to know is to borrow a Cpu off a friend and try there`s in your board.
Or your cpu in there board.
It`s going to be one or the other sorry to say.
What temps was the chip reaching on the overclock ?
Latest posts
