Build Advice Almost completed first build but have questions on CPU cooling, RAM, and CPU/GPU upgrade ?
Aug 6, 2023
4
I'm wondering if anybody sees anything wrong with this build? I'm debating between the 7600x and 7700x, and the cpu cooler.
I'm also wondering if the ram will be good for this build. Also if I save 130cad by downgrading my cpu to 7600x and spending an extra 200cad to upgrade my GPU to 7900xtx will there be a large enough bottleneck that would make it pointless?
Also I select d this cooler because I would like a cooler that doesn't cover the RGB ram if possible. Thank you very much to anyone who has advice.
Date: purchasing this week
Budget Range: 2800cad after tax
System Usage from Most to Least Important: gaming, media, some tech demos
Are you buying a monitor: No, I already have a 1440p 144mhz monitor I will be using
Parts to Upgrade: this is not built yet so anything you see that looks silly
Do you need to buy OS: No
Preferred Website(s) for Parts: memory express (price matching) and Canada computers
Location: Ontario Canada, will be building myself (first build)
Parts Preferences: amd and nvideas (no Intel)
Overclocking: Maybe
SLI or Crossfire: no
Your Monitor Resolution: 1440p
Additional Comments: I'd like my RGB ram to be visible
PCPartPicker Part List: https://ca.pcpartpicker.com/list/PCchPF
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor ($438.98 @ Amazon Canada)
CPU Cooler: Deepcool AK500 68.99 CFM CPU Cooler ($64.99 @ Canada Computers)
Motherboard: MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard ($278.98 @ Amazon Canada)
Memory: Kingston FURY Beast RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory ($179.99 @ Memory Express)
Storage: Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($159.99 @ Memory Express)
Video Card: XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card ($1139.74 @ Amazon Canada)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case ($139.99 @ Memory Express)
Power Supply: MSI A1000G PCIE5 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($249.99 @ Memory Express)
Total: $2652.65CAD before tax
Generated by PCPartPicker 2023-08-06 16:32 EDT-0400
Looks like your build listed above is good to go! I'd try and shoehorn another storage drive, one that's smaller in capacity and used for the OS and app's/game launchers. The larger drive can be used as your game library.
Thank you very much! I'll add a smaller drive for the os I appreciate it.
Did some tweaking to fit in a 7800X3D:
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($579.00 @ Amazon Canada)
CPU Cooler: Deepcool AG500 BK ARGB 67.88 CFM CPU Cooler ($49.99 @ Canada Computers)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard ($239.99 @ Canada Computers)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL38 Memory ($119.99 @ Canada Computers)
Storage: Kingston KC3000 2.048 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($151.51 @ iSanek)
Video Card: XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card ($1141.96 @ Amazon Canada)
Case: Deepcool CG560 ATX Mid Tower Case ($85.06 @ Vuugo)
Power Supply: FSP Group Hydro G Pro 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($179.99 @ Canada Computers)
Total: $2547.49
Generated by PCPartPicker 2023-08-07 02:32 EDT-0400
