[SOLVED] Alternate to corsair fan hub
Sep 22, 2019
5
I have just built a new pc with 3 corsair sp120 fans in the front which are connected to the motherboard. They are only showing red rgb. I dont have a corsair fan led hub but I do have the lighting node pro. Is there any way to change the rgb of the fans.
I7 9700k
Evga rtx 2070 black xc
16 gb g.skill tridentz
Gigabyte aorus pro wifi
Corsair crystal 570x ( the case didnt come with the fan hub for some reason)
Cooler master ml120 rgb
Did you use Corsair's iCue app? If this is your case, the Corsair 570x RGB, then you should've gotten the controller at the back of your case.
The 570X doesn't have a Lighting Node Pro or Commander Pro. You won't use iCUE out of the box. The RGB Fan LED Hub (that comes with the case) should have a push-button controller attached to it. Use this to change the lighting on the fans.
