Alternative PC cases and Power Supply for gaming build
Kyoushi
http://au.pcpartpicker.com/p/2yWzjX
Hi,
I was wondering if I could use an alternative to the case (NZXT Guardian 921 RB ATX Mid Tower Case) for this build as it's no longer sold in my area.
I'm told there is a lot of versatility to cases, so most mid towers should be fine, but as I'm not too sure, I would like to ask the wonderful people on this forum for their opinion.
Thanks.
EDIT: Also, I've come to realise the PSU in the build is out of stock as well. Would any PSU be fine for this build? Can anyone recommend me one?
As always, I appreciate the help 😀
So really would any mid tower case work for this build?
As in the components like the motherboard and stuff will fit just fine?
I have a Define R3 case myself! Though this build is for my friend and he's on a tight budget so I think that's a bit out of range for us haha
That's an matx board & your options are pretty much unlimited IMO.
The case you picked was expensive for a budget build anyway.
Id be looking for a coolermaster n200 if there's one in your area.
You want to think about an aftermarket cooler too - even a relatively cheap 92mm one - the stock amd cooler will drive you CRAZY!!
