Am I able to add a graphics card to an APU based system?
Cardinals21
78
I'm looking at a budget build that has an APU. Obviously at some point I would want to upgrade the graphics. Would I still be able to add a good graphics card? Or would that conflict with the processor or something? I would really like to know so when I do upgrade it my pc doesn't catch on fire or blow me up :) Can you guys help me?
Assuming you have an available PCI-Ex16 slot, you will be able to later add a discrete graphics card. The APU graphics will not interfere and your system will not blow-up or any other negative reaction.
-Wolf sends
Great! Thanks for your help. But what do you mean by discrete? Is there a difference between a normal one and a discrete graphics card?
Nope, adding the dGPU will turn off the APU GPU
As Wolfshadw has said, as long as you have the room in the pc to put it in, you're good
I know of two builds in my imeadiate circle that run dGPU with APU's
A discrete card is just a "separate" card that exists on its own. That is different than iGPU's (integrated) which are "part of/inside" of something else [in case of APU, part of the CPU die]
