This is how my case came:
As you can see. 6 holes and 1 metal standoff that can not be removed.
I tried installing the motherboard just like this and it would not start but as soon as id lift it up on cardboard Vola it would start perfect. Obviously with it having to do with grounding out I figured thats why the plastic standoffs were there (only included two)
So I installed them like this:
I never put any screws anywhere and the only place the mobo was touching was on the plastic and metal standoffs. It started! so I shut it off and installed 1 screw where the red arrow it, flicked the switch and pop. There goes my motherboard.
When I looked everything over (I was obviously rushing and not thinking) in the bag of goodies I seen metal standoffs
I arranged them like this and kept the plastic ones off:
It lines up with my mobo perfect and its all set up for the new one I had to buy. -.-
Before I go blowing my new one will this work?! Or am I just going to blow up another surface mount cap on my new motherboard and then ill be in depth $200 without a computer to use.
Also, Does it matter which screws I use? I was using the completely round headed one.
