Am I Running Too Hot?
George_204
Here's my max temps after about half an hour of gaming, Skyrim Special Edition, mid-high settings:
AMD FX-9370 - 74 C
AMD Radeon R9 280x - 93 C
That looks alarming to me, but I'd like a second opinion before I drop money on fixing / upgrading my cooling.
And yes, I've got lots of fans, I dust regularly, and my computer is out in the open with plenty of air flow.
I agree the FX 9 series is a horrible CPU.
74c after 30mins of gaming isn't the end of the world, its hot but still inside the normal parameters of temperatures.
now that video card seems bloody hot, I would inspect the thermal paste/replace it and make sure the fan is properly working/replace it
If you wanted low temps why did you put a nuclear reactor into your computer? Nothing keeps those 9*** series chips cool. And likely will eventually tear your boards power delivery up. And work its way to the rest of your system. Those chips never should have been released
So the FX-9370 typically runs too hot, but at the moment 74c isn't too bad - but the GPU is definitely running hotter than it should, and I should get it checked out.
Thanks!
