5400 - Orange and green light blinking 6 times
Description
A service error has occurred.
Resolution
Turn off the printer
Disconnect the power cable
Open the printer cover
Check for any orange protective tape or white polystyrene and remove if necessary
Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary
Close the cover
Reconnect and turn on
If the error message is still showing, then it is necessary to deliver or send the printer to an authorised repair centre.
If the printer is still under warranty, (generally one year from purchase) and supporting documentation is provided, then a free of charge warranty repair will be carried out.
If the warranty has expired, then any repairs can only be carried out at cost and charges will apply.
You can find the details of your nearest repair centre using our interactive repair centre locator.
