Hello,
I've done some modifications to my pc (added some argb and switched cables to new ones). So I booted it and a little after detected that the LED on the 500GB Silicon Power UD90 M.2 SSD was constantly blinking amber, it's continuous and non-stop. it starts from system boot (Windows is installed on this drive). It doesn't turn off even if PC is on Idle and absolutely nothing is happening. Blinking light wasn't there before (pretty sure about that) and I'm starting to be worried about it.
Also I have a 2nd M.2SSD, same model but 2TB, which is not blinking at all, even if under load.
Anyone know what's going on, or how to check if all is ok?
I ran a test of the SSD and it resulted in 0 errors detected. Also the LED starts blinking once Windows starts, when I'm in BIOS Setup it doesn't blink.
