Hi, I've had my PC for about 6 months now and it is great. The only down side is the sound produced by the amd stock fan and heatsink.
I didn't want to buy a new one but after reading what I typed I don't think I have a choice..
ambient temp - ~20C
idle - 35-40C, 2500-2700 RPM fan.
stressed (Prime95) - 55C, 3600-3700 RPM
The sound level at an educated guess would be 60dB when stressed so that is very loud and probably 45-50dB when idle.
I haven't OC'd as the power I get is fine for me.
I have 2 60mm fans at 7v (not 12v due to sound) for circulation and a 90mm fan (again 7v) for PSU due to case form.
There is a hole in the case opposite the CPU fan to allow air to flow in and out of there.
I just went ahead and stopped all my other fans and the cpu fan. The main amount of noise is from the CPU combined with the PSU, but the PSU has been upgraded to a Corsair for £40 so not changing that now lol.
I just googled the stock fan (right now it is attached to the computer lol) to find a picture for you all aswell, this is what it looks like.
http://www.overclock.net/attachments/amd-general/111487d1244602612-question-phenom-ii-x2-550be-owners-100_0129.jpg
Can you suggest a fan and heatsink that has a low noise.
ambient temp - ~20C
trying to find out what it was sent back for.
