AMD 8350 AND GA-990FXA-UD3 virtualization help
myke2424
Hello, every time I try to run a virtual machine (windows 8.1,2012,7 in particular) I get the error VT-x/AMD-V hardware acceleration is not available on your system.
I'm pretty sure my CPU and MOBO support it to. I'm currently using:
GA-990FXA-UD3 (Rev 4.0) Version: F1
AMD FX-8350
I tried checking my BIOS but their is not option for virtualization to be enabled or disabled.
I ran this program called "Speccy" and it's telling me that's enabled.
You can see that in the link below.
http://i.imgur.com/Btmmdok.png
If anyone could help that would be greatly appreciated, thank you.
The Virtualization option is located in your BIOS inside M.I.T. -> Advanced CPU Core Features -> SVM
That option usually comes enabled by default but check it to be sure it is enabled.
Speccy showing that is enabled makes me think its a software related issue, I've read on other threads of people having issues with Windows 8 + VMWare, not sure if you're trying with VMWare as well or if this problem is with Win 8 in general, you'll have to look around for other threads where people managed to solve this issue on Win 8 / 8.1.
