AMD A8-5545M running slow Help!
AMDMan5521
Alrighty so I'm new here! I recently purchased a HP Beats Special Edition 15-p030nr Notebook AMD A-Series A8-5545M (1.70GHz) 8GB Memory 1TB HDD AMD Radeon HD 8510G 15.6" Touchscreen Windows 8.1. I have read a bunch of threads but still to no avail I have not been able to fix my problems, so any help would be greatly appreciated. I have been running this system with turbo on so it is clocking at 2.7ish and the grahpics is clocked to, by the default high performance setting that the laptop has on it, and bench marking at 5568. For some reason Im running at a 10-14 in game FPS with everything turned on LOW or turned off with clocked and with out, I have seen no difference. I have seen you tube videos of people running this exact same laptop with near perfect graphics on ultra settings or at least high. I do not know what do to try and get this to run better. Also as soon as I run any program on it I keep getting 100% Disk usage as well as 100% CPU and I have no idea if this is causing the problem or how to fix both problems. I have ran AVG on it no virus, at system idle it still gives me 100% disk usage sometimes, and CPU is maybe 10-20% and memory at about 20-30. I have installed all drivers and updated bios I do not know what to do next please help me if you can.
