AMD Approved Power Supply
G
Guest
Guest
I am running an Athlon T-Bird on a Powersupply that is not approved by AMD. I heard somewhere that it should be approved. My manual to my motherboard only specifies that the power supply should have at least 10 mA on the +5VSB where mine has 1 A on the +5VSB? is this metric where it would be good enough? i haven't ran it that much since i bought it, so i don't know if it effected by it??? does it have to be approved by AMD???
Remember...Chixs dig guys who drive cars with big engines! :cool: !
Arrow
Splendid
Dec 31, 2007
4,124
It doesn't HAVE to be approved, but of course, it's recommended.
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
jlbigguy
1,001
Being AMD approved is more then just wattage and amperage. Since AMD chips produce a good amount of heat, an AMD approved supply will have exhaust vents on the BOTTOM of the supply (directly above the processor) to help remove the heat produced by the processor.
<font color=blue>This is a Forum, not a playground. Treat it with Respect.</font color=blue>
