News AMD-Based Blade 14 Is Razer's First Ryzen Laptop
Nice specs in certain aspects but the display is too small. It should have been a 15" minimum. As someone else said, 16Gb of RAM is entry level on a gaming machine anymore. The starting point for a high end build should be no less than 32Gb.
Reactions: TCA_ChinChin
Wait, 16GB soldered RAM doesn't mix up with a gaming laptop.
I know it's slim, the slimmest, but I'll take upgradable RAM for extra 2-3mm blindly. Or at least, put 32GB on the 3070 & 3080 options for the same price (even with Ryzen 7 5800H instead, I don't mind this, I bet the delta between those APU's is larger than the RAM for Razer).
And please, where's the 16:10 16" panel?
I got the RTX 3080 version and so far so great. Doesn't seem to run any hotter/louder than my G15 with RTX 3070. And to those saying it should have been a 15" display, that sort of defeats the point. They already have a 15.6" model and there's plenty of other products in that range. The main appeal of this, and the reason I decided to bite, is due to the smaller form factor. It's definitely a niche market, so if you don't want something so small, there's a bunch of other great 15.6" options for cheaper, including the awesome G15.
