AMD Build. First Time Build. Some Problems Exist
TechGuy99213
14
OK, I have never built a PC, so please bare with me. I have an ASRock 970 Extreme3 R2.0 motherboard, an AMD FX 6300 processor, and an evga 600 b power supply. I believe thats where my problem lies, but if your curious, i also have 2 8 gig sticks of kingston ram and a 2.0tb hard drive (cant remember manufacturer). i attached a nothing special graphics card for now, since the motherboard has no graphics.
Everything went well when building. no surpises, no setbacks. first time I powered on, it seemed to go ok. the case lit up, the fans (included the one on the cpu) turned on. however, i didnt get anything on the screen. Also, I cannot open the cd drive I attached.
At first I thought that there was something wrong with my sata connections because of the cd drive, but if my harddrive wasnt detected, the pc would beep at me, no? I got no beeps. So, what do I have to do to see something on my screen? I didnt even see a bios boot.
any help or direction would be greatly appreciated.
Make sure the video card is installed in slot PCIE2
Make sure that the GPU is fully seated. There is a latch at the rear of the slot that can interfere with proper seating.
Make sure that the 8-pin CPU power is connected.
Make sure that the 24 pin ATX power is fully seated.
Make sure any 6 pin power connections for the "nothing special" GPU are connected.
Check that the "nothing special" GPU is in fact expected to work. In some cases, a PCIE 1.0 card won't work in a modern machine.
If still no luck, list full system specifications including monitor.
