AMD CCC Driver not working properly [HELP]
xxkellerman
18
So i've downloaded Battlefield 4 and went into the game, then i got an error message saying i needed to update my driver. So i went to the amd site and downloaded the latest beta driver and uninstalled all my amd software, then installed the beta driver then restarted my PC. When i go in my CCC it looks like this:
http://shrani.si/f/h/j7/3A79pQYN/ccc.png
When i launch Battlefield 4 i get this error:
http://shrani.najdi.si/?3R/qi/1S9cpb22/error.png
I've installed 13.10 BetaV2 driver
My card is HD 6850
OS: Windows 8
How did you uninstall the software? I would download the 13.9 package. Use the amd uninstall button to remove the current drivers. Then install the 13.9 package. The beta drivers contain benefits for xfire users. The 13.9 are stable for your card. Do the auto install as it will install other software needed for CCC and the video. Once you get it work please note when upgrading amd drivers you do not need to uninstall each time. In this case it looks like you uninstalled other needed files that were not provided in the beta.
Still the same as before. Used the uninstall software and removed the drivers then used ccleaner to fix registry (several ATI Errors). Installed latest non-beta driver (13.9) still same window and still same error from BF4.
