Hello,
Recently, I found out that my AMD FX 8350 8 core Processor has been Parked by Windows 7
http://i.imgur.com/kGHHtuI.png
I found out that other people had the same problem but used a Hotfix by Microsoft (http://support.microsoft.com/kb/2646060) But unfortunately, for some reason, that did not work for me. I then tried the Unpark CPU App and that did not work either. So Finally, I tried to edit RegEdit and change "ValueMax" to 0 (http://forum.cakewalk.com/Windows-7-amp-Core-Parking-a-better-way-to-Turn-It-OFF-m1861804.aspx) But, Yet again, It did not work and I still have 4 parked cores, So Is there any way to fix this or should I just attempt to contact AMD Support?
Thanks,
-Joe
Thanks,
-Joe
