AMD Crimson 17.10.1 Problems
guncha3773
4
Hello,
So i have a problem which i didnt think is a problem. Like few months ago my AMD settings showed there is new drivers avaiable. So i installed them but at the point when the skreen starts to flash and change resulutions my mouse and screen started to lag. After the reboot still lagging. I did system restore to go back on old drivers. I toght its mybe buggy drivers il w8. So i was working a lot not playing, And since Friday i m trying to update drivers again. I want to amd home page took exacly drivers for my card but still lagging as hell. I red in internet that some people gan go max 17.9.2 Im was trying to install the newest 17.10.1 and 17.9.2 but no luck these drivers were from amd homepage. But than i realised i cant open radeon settings anymore... So i deleted all drivers completly downloaded last drivers i had and still no radeon settings so i went back as 15.3 to get radeon setings back and now im stuck where i was it says there is new drivers 17.10.1 which i install and get heavy mouse and screen laggg
Hopping for some smart sulution.
Thanks !!!
Running
Win7 64bit
AMD Radeon R9 380 4gb
AMD Athlon x4 750k 3.40Ghz
8gb ram
Motherboard Gigabyte Technology Co. Ltd. F2A7
Monitor i use Sharp - LC-49CUF8472ES with hdmi
First I recommend using AMD's Clean Uninstall Utility: http://support.amd.com/en-us/kb-articles/Pages/AMD-Clean-Uninstall-Utility.aspx
Run that but do not restart yet.
After that download DDU: http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Restart into safe mode and run DDU clean and restart.
Once back into windows download and install the last known working driver for your pc.
My wife has the same GPU (380 4GB) and so far 17.11.2 seems to be working for her (I haven't bother updating yet because the 380 drivers can go from good to bad) but I can confirm that one is working on that card.
So i used AMD's Clean Uninstall Utility than ran the ddu in safe mod made amd auto driver detect to run it went again fro 17.10.1 and installed it til eend of instalation everithing was fine. After restart mouse lagged so hard and pc just stuck in welcome screen so i went in safe mode made system restore again. After restart i wanted to go in amd settings to check to witch drivvers it rolled back but again i cant open radeon settings now wtf is going on. And i wanted to update the drivers because multiple games was alerting me that i have old drivers.
Only other suggestion I can make is reinstall windows.
Before that i better w8 for some more answers
So i did some upgrade went for Asus M5A78L-M LE/USB3 Motherboard and AMD FX 8350 Processor did new clean windows install still cant go over last of 16... drivers 🙁 i think my Gpu is meesed up or something...
