I can only speak for Intel 520s, but they work perfectly fine in x4 slot so long as you're only using one port
x4 would work, if it's open-ended. The cards I'm talking about are
physically x8, so they need either an open-ended slot or one that's at least x8 in length.
As for how much bandwidth you actually
need, PCIe 2.0 has roughly 500 MB/s (4 Gb/s) of throughput per lane, so four slots should be plenty for running a single port @ 10 Gb/s. I'm not aware of a PCIe card that won't work, at all, in fewer lanes than it was designed for. So, put in a slot that has just one lane connected and 4 Gb/s is what I'd expect to achieve.
(just need to be willing to demel an x4 slot if needed!).
Sometimes, there are other components in the way, once you go past the end of a shorter slot. I have a B650 board that's quite the opposite situation, where it has 3 slots that are physically PCIe 4.0 x16, but only have x1 lane active!
I did move on to 710s when I built my new server and primary machine though because I still wanted full bandwidth and client platform lanes <insert rant here>.
I got a server board with built-in 10 Gb/s NICs, because it's micro-ATX form factor and has just 3 slots. If you put a 2.5 width graphics card in the x16 slot, that'd be your only PCIe card! I don't have any plans to do that, but the weird decision they made was to put the primary slot at the top. So, even a 2-wide card would block the middle x4 slot and force you to either run it at x8 or forego the 3rd slot.
So, I reasoned that it's not a good move to plan on using a network card in there.
