Amd fx 4130 help overclock
kevin11121
31
Hi i got a fx-4130
-asrock 960gm-vgs3fx motherboard
-corsair 600w power supply
-gigbtye radeon 7970 1000mhz overclock
- corsair h55 cpu water cooler
-Team Xtreem Dark Series 8GB 99924 1600mhz 1.65 volt memory
When i overclock to 5, 10 or 15 percent in bios when i run a prime 95 the Core multiplier drops from 19.5 to 7 and thus makes my core very slow it fluctuates between 3999mhz and 1600mhz. This of course is at stock 3.8. Also the Asrock 115%x boost doesnt work my ps doesnt start. HALP ME
When i try amd overdrive with cpu i do the test and it will freeze/reboot and not complete the test. Note Max cou temp is 50 degrees Celsius and Minimum 38 degrees
i Love anyone that can help me, should i rma my processor or motherboard or psu? i lag in skyrim when i shouldnt on 3.8
I have quiet and cool turned off
Cpu overclock voltage on 10%: 1.45 15%: 1.55 my motherboard is 1.55 max i played with other settings and nothing seems to work what should i do, this processor and motherboard should have ok overlocking potential...........
G
I've never trusted asrock boards, I sudgest trying a Gigabyte or Asus or Biostar board. Try setting the multi manually if you have that option, then try to set the FSB manually, +1 then reboot and stress test.
