amd fx 6100 running to hot?
Oct 24, 2014
14
im getting horible fps drops in diablo 3 certain areas. opening npc.s etc. as soon as i close the tab of a npc or stash the fps jumps back up to 75+ but while in npc or stash the fps drops to 2-10 fps. noticed that my cpu running on average 65 degrees c not on a load.. might that be my problem? or is it somehting else since it only happens at certain points of doing something in the game
? might hit 75 as well under a load
D
If its the stock one its normal you need to change it id recommend hyper evo 212 or any cooler master cpu cooler in that range.Most stock coolers are garbage so id change it quick
its normal if you have stock cooler.Please check if its stock or aftermarket than i can maybe help u
stock im pretty sure
also i am beginning to think that my cpu and or mobo is the cause. thanks for the reply
here is my basic system info as well. maybe you can do some research for me . im not that perfect when it comes to all the pc tech stuff but im pretty much able to do whatever with a little guidance
Operating System
Windows 7 Home Premium 64-bit SP1
CPU
AMD FX-6100 67 °C
Zambezi 32nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 669MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co. Ltd. GA-78LMT-S2P (Socket M2) 36 °C
Graphics
DELL SP2009W (1680x1050@59Hz)
2047MB NVIDIA GeForce GTX 760 (EVGA) 32 °C
Storage
465GB Hitachi HDS721050DLE630 ATA Device (SATA) 30 °C
Optical Drives
Optiarc DVD RW AD-7260S ATA Device
Audio
Realtek High Definition Audio
