Amd fx 6300 max temp.
Sapph1re
Hey guys, I have fx6300. Cpu is locked 70 deegres. That does'nt go higher. Accordingly, I am having some problems. Seems like cpu throttling. How can disabled it? I can't find bios setting.
after 15 min prime 95 tests
it is a saflety feature. there is an option in bios called "thermal throttling" you can disable it but your pc will shut down instead. lower your overclock (voltage is what causes the heat) or get a better heatsink
Thanks for your answer but thermal throttling already disabled. You are right about heatsink. I used stock cooler. My problem still persists.
