I recently bought a build off a guy who was selling it. He has a lot of experience building PCs so I was comfortable buying it. It ran great for a while and he stress tested it to make sure it was stable. Just a few weeks ago the temps starting to get hotter. My cousin likes to play Runescape and after an hour or so it gets too hot and the PC shuts down. I ran Prime95 and the temp will go up to 70-80C within a minute or two so I have to stop the test. I tried reapplying the thermal paste two times. Granted it was my first time, the 2nd attempt looked much much better than the first.
My idle temps are 2-3C if that helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106102 this is the heatsink he put into the build. I was thinking about downgrading to something smaller because this heatsink doesn't fit 100% on the CPU due to the Sentey fan above it.
Specs for reference:
AMD FX-8150 3.6GHz Eight-Core CPU
AMD XFX HD 7850 1Gb
8GB G. Skill Rip Jaws
ASUS M5A78L-M LX Plus AM3+ AMD 760G Micro ATX
Sentey Optimus Extreme Division case
I'm very new to fixing things inside the computer so maybe I am doing something wrong, but I have no clue where to go from here. Very frustrating to say the least. Any help would be greatly appreciated. If I forgot any information or you need me I'll try to provide it.
AMD XFX HD 7850 1Gb
