Amd fx 8300 max temperature
Andrew97
38
I wonder what temperature is max and safe for amd fx 8300, i played shadow of mordor and it reach to 70*c. I dont have an stock cooler.
When he reach that temperature the game have fps drops everytime...does is normal?
its not normal, its called thermal throttling
install amd overdrive
it will show you your thermal overheads
So i need to disable thermal throttling?
the cpu is slowing itself down to not die from overheating
you need to remove the cpu cooler, clean off the old thermal paste, and then reinstall it with new paste
https://www.youtube.com/watch?v=SST61g3hnIs
also check to make sure the cpu cooling fans are actually spinning
In idlle it stays at 38-39-40*C so i need to change thermal paste right?
idle doesnt matter
you using amd overdrive to check thermal overhead while under load right?
It reach at 13*C while i was in game, when is idlle is on 33.0
Yea 70*c seems pretty high. Im not an expert but I also have a stock fx 8300 (~18*C in idle) which runs @ 3.3Ghz + EVO 212 heatsink and after playing Fallout4 in ultra for about an hour the max temp it got to was 41*c (core temp software results).
Latest posts
