AMD FX 8320 cpu black RUNNING HOT!!! help Idles at 57*C
Alex Mazurek
6
Hey guys ever since the day I installed my AMD cpu it has been running hot from the start. (I'm not sure if this is a problem that's why I'm asking)...
When idling in BIOS it's at 57*C and 134*F .. Some times after running my pc over an hour I'll get a warning sign pop up saying "warning CPU at 65 centigre"
I'm wondering if this is normal? I'm in the process of trying to overclock it and I don't want to do so if it will make it even hotter.
I tried taking my heatsink off cleaning off the old thermal paste with rubbing alcohol and put new paste on and CPU temp didn't change at all. I'm thinking of trying my stock heatsink but it's such a pain in the dick to put my aftermarket one on. May have to breakdown and get a $100 heatsink.
The biggest kicker here guys is I'm in southern Florida where house temperatures NEVER dip below 80* in the summer. My computer room is about 85* at all times. Normal AC always set to 78 but always hotter in computer room.
Thanks in advance,
Alex
Constantly have a big stand up fan blowing at my pc from the ground and an overhead fan always on as well
SPECS*
AMD 8320 FX black (stock not overclocked)
Asus M5A99FX pro R2.0
Asus GeForce GTX 750ti GDDR5 2gb-oc
Thermaltake Chaser MK-1
4- 200mm case fans (all working)
1-140mm case fan
Arctic Freezer 7 Pro Rev 2 150 watt heatsink
Apevia ATX Aq700w aqua power supply (with fan)
Crucial Ballistix Sport 8gb kit DDR# 1600 RAM
WD blue 1tb Sata 6gb/s 7200rpm
Samsung 850 Evo 250gb sata
hitachi 250 gb
3- Acer 27 inch screens (G276HL)
Thanks for the reply guys but that's what my first reaction was. That's why I stated above I took it apart scraped off all the thermal paste with rubbing alcohol (works great) and put it all back together perfect. ( 3 Times now) so that is not it... I think its just because I live in Florida and its 83* F in my room (90+ outside in summers everyday )
I don' think so, It's pretty open under a glass desk. Also I have a standing fan next to it to blow cool air in. I posted a pick below of the setup.
I have a side 200mm fan sucking in blowing at gpu and part hits the cpu
built in fan on bottom of psu sucking in from bottom
2- 200mm fans on the top of build sucking air out of inside blowing out threw the top
front 200mm fan below dvd player sucking in cool air blowing inside
back 140mm blowing really good directly at cpu/heatsink
I just looked around inside to confirm this and feel the fans and it does feel cool inside with great airflow.
lastly my CPU heatsink fan is facing the BOTTOM blowing through heatsink towards top to get sucked out by top fans
I think that air flow makes the most sense unless I'm seeing something wrong here?
photo.php
data:image/jpg;base64,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
Everyone thanks for helping. I found out it was just my BIOS running that "hot" 57. I downloaded multiple different applications and they all say around 42*-43* Thanks for all the help. Now onto overclocking this SOB
