AMD fx 8320 running crazy hot
Martin1982
911
I just made a new build for a girl who needed a pc for games/editing the problem is the cpu is runing crazy hot 50-60 celcius at IDLE havent even installed a game yet.. the cpu was not even running @ 50% load.
Cpu is installed with stock cooler and thermal compound from an coolermaster 212 evo in a small Pea at the center of the cpu.
Anyone got a solution my best idea is to buy a 212 evo for her, im just thinking that you shold be able to use the stock cooler witn no overclock.
Case: comrade Bitfenix
MB: Gigabyte 970a-ud3p
Cpu: AMD FX 8320
Cpu cooler (stock)
Fan 120mm exhaust at top of cabinet
That's very good. Too much heat paste is worse than not enough.
You could try running with case side off briefly & see if that makes a difference? (Just to eliminate poor airflow as a possible cause). If it's still running really hot, I would be tempted to take the cooler off, clean everything down and reseat it. What are you using to measure temps?
Little thermal paste is required; it's purpose is to fill the voids between the heatsink and the processor. I prefer using an old and clean credit card to spread a very very thin layer of paste as I'm then sure the whole CPU is covered. If you"re not thinly spreading it, then using a grain of rice should be enough.
This is an incorrect statement; while in the BIOS the CPU is working and it should be much cooler when the OS is loaded and the system is idle. Test it using Prime95 torture tests and check how warm it gets.
yeah you are right i got a 8350 @ 4.4 for myself, but this is for a friend and she will mainly use it for designing and photo editing and i bit light gaming.. if it was mine I would throw in a cooler master 212 evo and bump it to 4 ghz
