Well, I have an overclocked AMD FX 8320 (4.72GHz, 1.428V) on a Gigabyte GA-970A-UD3 Revision 3 motherboard, and I'm experiencing CPU throttling even though the CPU temperature in CoreTemp never exceeds 47C during a 5h Prime95 run (it jumps between 46C and 47C).
I also have a problem where the CPU frequency fluctuates under load, multiplier drops down from 23.5 to 14.5 on random cores during the Prime95 run. Doesn't happen when HPC mode is active, but that thing gets on my nerves since Prime tends to fail for no good reason, same happens if I leave SpeedFan open while running Prime95, one core shuts down within a minute even though I can stress the CPU with Prime95 for more than 12h if I use CoreTemp instead of SpeedFan. Stupid software...
I've also tried benchmarking it on Debian Wheezy using mprime (Prime95 for Linux) and the CPU frequency doesn't fluctuate at all, it stays stable at 4.72GHz until it drops to x7 (throttles), and the temperature never exceeds 46.4C.
Full hardware specifications are:
CPU: AMD FX 8320 eight-core processor (4.72GHz, 1.428V, all cores enabled)
Mobo: Gigabyte GA-970A-UD3
RAM: 4x2GB DDR3-1333 Transcend JetRAM CL9
Graphics: XFX AMD Radeon HD 7770 Core Edition
PSU: XFX Core Edition 550 Pro
HDD: 1TB Hitachi Deskstar HDS721010CLA330
SSD: 120GB Kingston V300 SSDNow SV300S37A120G
Cooling, I'd say I have a well ventilated case. it's an ATX midi tower with 3x92mm 2000RPM fans on the front that push air in, 2x92mm fans on the back and 1x92mm on top pushing air out (2000RPM each), 1x60mm 3800RPM fan for Nortbridge and 1x60mm 4400RPM fan for VRM cooling. CPU cooler is an Arctic Cooling Freezer 13 with disabled PWM that spins at 2300RPM (I didn't have money for better, though this one is apparently doing a good job too).
All power-saving features (C6, Cool & Quiet, C1E) are disabled, even some virtual machine thing as well since I don't use VMs, I dual-boot instead.
I honestly have no idea why this happens, all should theoretically be good and the CPU is running 15-16C below 62C max on the same voltage it uses for Turbo. So, does anyone know what the problem might be? I'm kinda running out of options to try here.🙁
