AMD FX-8350 Chipsrt intalled, but no CCC? (Catalyst Control Center)
immenjake
6
So, about a week ago I built my own rig... The Goods:
An ASUS M5A97 LE R2.0 MOBO
An AMD FX 8350 8-Core Unlocked Black Ed. Processor Veshira series
An Nvidia GTX 760 EVGA Ed. W/GPU boost 2.0
A WD Black Ed. 1 TB HDD
Standard ASUS DVD/RW Optical Drive
8 GB DDR3 Corsair Vengange Black Ed. RAM (2 DIMM)
and a Corsair CX750 PSU
So, the system is working fine, great speed, boots fine, and runs games and whatever I need it to run flawlessly. The only "issue" I am having is with the AMD chipset Drivers. I used the Motherboards disc that came with it and installed all the onboard devices drivers and everything went fine and it even did intall the chipset. However when I right click I can't see my AMD Catalyst Control Center option like I have on my AMD processor on my Laptop. I also have a couple friends with the same processor and they have this control panel. I have the Nvidia control panel and that works fine and everything else on the PC is running flawlessly. I am a bit of a perfection artist and this is my first build so I would like it to be perfect. If anyone could give me any kind of Advice it would be so greatly appreciated.
Thanks in Advance, Jacob
What will you do with AMD catalyst driver using an Nvidia card? AMD Catalyst`s function is mostly tweaking the graphics settings and you simply cannot change your NVDIA`s Graphics settings using the AMD Catalyst.
Yes if you have an APU you will be needing the CCC for tweaking the iGPU but in your case you don`t need it.
