AMD fx8350 on sabertooth 990fx r2.0 , core speed and multiplier keeps changing every 2-3 seconds
normal it revs up and throttles down as needed like some little background program may kick it in and rev it up and then go back down
nothing to worry about intel does it to
may look at task manager to see whats running or if its a service you could set to manual from auto
Completely normal. It's to save power I think and also keep the computer cooler.
You could change this in bios. But would only be necessary if your overclocking.
GLHF!
Latest posts
