Amd ga78lmt-usb3 with Zotac Omega 980 ti
Mason_9
Commendable
May 4, 2016
12
I want to upgrade my graphics card to the one to the title my cpu Is good enough just makeing sure my pci slots CAn handle it
Yes. The Seasonic is great. The XFX is also great. You won't go wrong with either. If you plan on OC'ing either the card or the FX-8350, you will want the best 600W+ PSU you can get. You won't want the Evga 600W if you OC.
Gold, silver, bronze are simply efficiency levels. Power factor ratings. How well the PSU converts your electrical power at the socket to usable energy at the PC, and how much is simply wasted. It has no bearing on quality, except indirectly.
