First of all, I'd like to tell about my specs
PC Specs:
CPU : AMD Ryzen 3 2200G 3.7 GHz (OC)
GPU : SAPPHIRE RX 570 Nitro+ 4GB GDDR5
RAM : ADATA Premier 8GB 3000MHz (OC)
Motherboard : Gigabyte GA-A320M-S2H Ultra Durable
HDD : Toshiba 1TB
SSD : WD Green 120GB
PSU : Corsair VS550
OS : Windows 10 Pro 64-bit
(OC) Stands for overclock.
So after searching plenty of forums and videos I decided to make thread as my last hope, As the title says I'm not getting fps because my GPU is not using like 90-100% utlization. I've made thread on AMD forums but some people said that my CPU is bottle necking my GPU and said to change my CPU. So, I browsed in internet if my CPU is really bottle necking my GPU and found this https://pc-builds.com/calculator/Ryzen_3_2200G/Radeon_RX_570/0Po0Yl44/ as you can see there are no possibilities to get bottle neck. So in past 2-3 days ago I reinstalled my windows from original source website then after installing some drivers and I ran games on fresh windows (I don't have pirated games) and I found that my gpu was using 90-100% I was happy that It got fixed but after few hours that problem started again so I had doubt that I installed something that caused this. After that I again reinstalled my windows to fix this and then I got same result that it got fixed again so after that I didn't installed any software expect drivers for one day so next day after windows update the problem started again. The games I've tested are GTA V, PUBG PC, CS:GO all 3 games are not using high usage but PUBG PC LITE and Metro Redux 2033 are working fine and using 100% usage. I want to know what is causing this. Please help me.
Edit: I forgot to point that when I set some settings to low like graphics, details fps are not increased but GPU usage gets to the 20-30%
PC Specs:
HDD : Toshiba 1TB
PSU : Corsair VS550
