AMD Motherboard Help!
N00b_of_PCs
101
Looking to run games like Skyrim and BF4 on settings better than console ones, so these components were recomended to me. I hear this is a pretty solid setup able to play on the higher spectrum of settings. However, since this is a budget build, the i3 is pretty expensive - the current price being $120. Can someone suggest me an AMD motherboard $50-70? Thanks.
CPU: AMD Athlon X4 860K Black Edition 4000MHZ 4MB 95W FM2+ Processor
Motherboard: AMD motherboard? You decide!
Memory: Dell Memory 8GB (2x4GB) PC2-5300 SNP9F035CK2/8G
Storage: Hitachi Ultrastar 500GB 3.5" 7200RPM Internal Hard Drive
Video Card: XFX Radeon R9 270X 2GB Double Dissipation Video Card
Case: Rosewill Dual Fans MicroATX Mini Tower Computer Case FBM-01
Power Supply: Corsair Builder Series CX 500 Watt ATX/EPS 80 PLUS (CX500)
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($89.98 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($25.98 @ OutletPC)
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard ($97.99 @ SuperBiiz)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive ($69.99 @ Micro Center)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($43.99 @ SuperBiiz)
Video Card: MSI Radeon R9 270X 2GB TWIN FROZR Video Card ($149.99 @ Newegg)
Case: Azza SIRIUS ATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: Antec TruePower Classic 750W 80+ Gold Certified ATX Power Supply ($49.99 @ Newegg)
Total: $617.89
Generated by PCPartPicker 2015-02-06 01:33 EST-0500
the memory you have selected is server memory, and will not work in a desktop. I don't know what your budget it, but look at the build i posted above. you cannot do better for $600 then that one.
Originally, I was going to use an ASRock FM2A88X PRO3+ Socket FM2+ 95W / FM2 (motherboard) and G.Skill Ripjaws Series F3-12800CL9D-4GBRL 4GB (2 x 2GB) DDR3 1600MHz (memory). However, this motherboard does not have the best reviews.
My targeted budget is $450
ASRock FM2A78M-HD+
http://www.asrock.com/mb/amd/FM2A78M-HD+/index.asp?cat=
price range 50-60$
Asus
A88X-PLUS
http://www.asus.com/in/Motherboards/A88XPLUS/specificat...
50-70$
look at this
never EVER buy Asrock for the FM2/FM2+ platform. They make fine Intel motherboards, but those FM2+ boards will burn your house down. legit junk.
Gigabyte or AMD only, only a88x motherboards and only motherboards with heatsinks on the VRMs.
[/quotemsg]
So would this be a good motherboard? Its a GIGABYTE GA-F2A88X-UP4 FM2+ / FM2 AMD A88X (Bolton D4) HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard.
