AMD overclocking need help
calrag
20
Alright so I want to overclock my cpu, the only thing that's stopping me is that I have no idea how to do it. Should I use AMD overdrive or the bios?
My CPU is AMD Phenom II X4 955 BE 3,2 GHz 8 MB
You were just like me when i wanted to overclock my FX-6300. Dont worry! Just look up guides online but look them up for your motherboard. So i had a Gigabyte 990FXA-UD3 and that's what i searched. Also don't use amd override. The bios will make the OC more stable and maybe even easier. Good Luck!
