[SOLVED] AMD Phenom II X4 955 rapidly changing from 800 mhz to 3200 mhz.
Oct 31, 2018
5
so in cpu-z i am rapidly going multiplyer x4 to x16. Every couple of seconds it will change very rapidly causing nothing to work. just added thermal paste to the cpu. any help?
That's just AMD Cool'n'Quiet. It's a power saving technology that will make your CPU speed up or slow down as necessary. If the CPU usage isn't out of the ordinary, it's nothing to worry about.
You can disable it in the BIOS if it bothers you though.
Im Quite new to this cpu thing, but Im Running windows 7 which i think your talking about and what would be kicking my cpu into turbo mode?
