Amd PII 920 heat problems??
rajiv babu
38
I have an AMD Phenom II x4 920 processor and Gigabyte GA-MA785GM-US2H mobo.
When i run the stability tests in AMD Overdrive, it shows temp upto 62-65* C.
Is this normal??
I use the stock cooler which i recieved with my pro. Should i change the cooler?? or is this the problem of my case?
