AMD R9 295X2 Water Cooling Mod
gravemansam
33
Looking at the new R9 295x2 cooling system and I want to integrate it into a full case loop with the cpu and bigger rads. I have looked all over for a mod for this particular kind of radiator with no luck. My only real concerns are what kind of fitting is used to attach the hoses to the radiator? It doesn't look like barbs or compression fittings, so is it even possible to integrate it into something else without just cutting the hoses and putting them on barb fittings? Also I am curious how the pumps will work in a loop with a MCP 655? are there any issues that ight arise? I am planning on getting 2. I have done a lot of modding but never a closed loop into a full loop before.
Thanks for any help.
Do you think they will actually make a water block? The 7990 only had 1 ever made by EK because the 7990 only had air cooling. This already utilizes liquid cooling so i feel like the chances of a water block coming out are slim. Not to mention EK was working with AMD when they made the 7990 water block which i believe came out shortly after the 7990 launched and there have been no rumors that I can find of anything like that happening now.
