AMD Radeon 6800 HD randomly crashes to black screen, wonky sound, not reproduceable error.
LeCocoPanda
Hi everyone;
Been having trouble with my AMD Radeon 6800 HD card, I think.
Symptoms:
- Cut to a black screen.
- Alternatively, when enabled "Graphics OverDrive" in "Performance" in Catalyst Control Center, instead of cutting to a black screen, it cuts to a bunch of linear cubes, then black. No error is displayed.
- Sound plays as normal for a few more seconds, but goes wonky after.
- Unresponsive to anything. Cannot Ctrl-Alt-Delete or Alt-Ft. Requires a hard reboot by pressing power button.
- It's considered disconnected to any online services (Vs. when a program crashes sometimes it's still "online" if you don't close the error prompt)
It seems that I can play multiple games at the same time with no problems (For example, Starcraft 2, Tropico 4 and Sims 3 at the same time ), but when I run the MMO Mabinogi, this occurs after an entirely random time. It is not reproduceable. There is no common denominator. I could be killing monsters, or fishing, or just AFKing. It could happen as soon as I start the program, or it can happen 6 hours in.
Doing a quick google search suggests that it is a problem with the card as I found similar issues with another game but no solutions. - Forum - Technical & Account Support - Computer Crashes after random time played. - Path of Exile
Things I've tried but didn't work:
- Reinstallation of the game
- Registry cleaning
- Changing settings on the "Overdrive" in Catalyst Control Center.
- Resetting all settings to Default in the catalyst Control Center.
Any help would be greatly appreciated. Thanks in advance.
System Information
Time of this report: 4/7/2013, 15:01:48
Machine name: PANDA-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 02/05/10 19:13:52 Ver: 08.00.10
Processor: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 8192MB RAM
Available OS Memory: 8174MB RAM
Page File: 2760MB used, 13584MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon HD 6800 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x6738)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_6738&SUBSYS_23051787&REV_00
Display Memory: 745 MB
Dedicated Memory: 1010 MB
Shared Memory: 3830 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: Hanns.G iX191
Monitor Id: HSD2528
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: HD15
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64 .dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1172 (English)
Driver Version: 9.12.0.0
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 12/19/2012 16:08:04, 1151488 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-2478-11CF-A370-0F03BEC2C535}
Vendor ID: 0x1002
Device ID: 0x6738
SubSys ID: 0x23051787
Revision ID: 0x0000
Driver Strong Name: oem36.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_NI:9.12.0.0ci\ven_1002&dev_6738
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Hi,
I have the exact same card with the exact same issue and I am really interested in whether or not you sorted this out?
I've tried a lot of things and run diagnostis on the card. My temp doesn't seem to get too high (maximum of 75c) but my gpu usage is always at about 99 when running any kind of game or benchmark test regardless of settings.
John
Hey guys, I too have been noticing this issue. Recently I have Uninstalled the driver and reinstalled it and that has worked for me. However I'm not sure how permanent the fix is as I feel as though I did it about a year ago as well.
