AMD Radeon HD 4350 running at 110MHZ instead of 600MHZ
help i am not getting the right clocks for my GPU at readings it says that the max clock is at 600MHZ but at current reading it is only running at 110MHZ how can this be ?
It is running at much lower clocks when idle, to save energy. Try checking the clock again while simultaneously running a game or graphics benchmark, it should be correct then.
