AMD Radeon HD 7950 "No Signal" when using HDMI port
Gibson39
Commendable
May 25, 2016
Been having this problem recently and bought this rig from someone as I cannot build it myself. Limited computer knowledge and I'm only really able to figure things out by googling it. I've dug through a bunch of topics with a similar issue it seems, but most barely help at all.
Trying to see if I can go to a dual monitor setup and the only available port working is my DVI which works fine. However when I try to test out the HDMI port (when the dvi is unplugged) the monitor says "no signal" but reacts in a way that it recognizes something is connected, i.e waking up from sleep. Frustrating that the DVI works, but not HDMI. I've tested the HDMI cord by hooking my another computer up to my monitor and it works fine.
I've updated all the drivers and made sure the software is up to date, tried messing around with BIOS but everything I see in regards to that doesn't show up as an option in my settings.
As of right now, I'm stuck trying to figure this out on my own. Any suggestions would be greatly appreciated.
System Info:
OS Version 10.0.10586 Build 10586
System Manufacturer MSI
System Model MS-7752
Processor Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz, 3100 Mhz, 4 Core(s), 4 Logical
Installed Physical Memory (RAM) 8.00 GB
AMD Radeon HD 7950
HP Pavilion 27bw Monitor
Input isn't the problem. Even with the auto-detect disabled it still cycles through the inputs searching for something until it say "No Signal"
Monitor then goes to sleep and awakes if I unplug the HDMI cord. Also awakes when I plug it in but then cycles through again and the process repeats itself.
