AMD Radeon R7 200 driver problems
sheedysleftfoot
Hi, I have just purchased a AMD Radeson R7 200 and no matter what I do I can't get the thing to work, there seems to be an issue with the drivers.
I am running a Intel core i5, 8gb on windows 7 ultimate. Motherboard is a gigabyte h57m-usb3
I have uninstalled all old drivers with the Guru 3d driver clean up software. I have attempted to disable signed drivers in windows as that appeared to be a problem. I have installed the latest AMD drivers using their auto detect utility and also checked that I don't have the windows service pack problem. And I still get the error message;
On start up I get the following error;
No AMD graphics driver is installed or the AMD driver is not functioning properly. Please install the AMD driver appropriate for your hardware.
If I try to use catalysts control centre I get the following error.
Amd catalysts control centre cannot be started. There are currently no settings that can be configured using AMD catalyst control centre.
In device manager It believes I am running driver 14.501.1003.0 and that the driver is up to date.
Any help would be really appreciated. Thanks.
Thanks, tried that. Still the same problem with windows wanting signed drivers. I shall return it and get a different card.
